jessedacri
Alright, bear with me here, have an electrical gremlin that I'm hoping is not something expensive or is simply a defect - I recently bought the following brand new:
Mamba X
Holmes Hobbies Puller Pro 2700kV standard
Holmes SHV500V2 servo
Spektrum DX5C with SRS6000 receiver
Built a 10.2 raw builder's kit and fit everything to it and all has been well for about 3-4 packs. I've been running mostly 4S on 5-year-old 3300 packs which have already netted me hours of very, very slow crawling and some high speed trails.
Anyways, since I haven't finished my hilux body yet I found a way to fit my "clean" TRX4 bronco body on, stuck my "beater" bronco body on the TRX and went out with a friend to Vasquez Rocks on Saturday. I plugged the PowershiftRC LEDs into a traxxas JST splitter. Had a blast for 2+ hours and then the truck froze up completely and the Mamba rebooted. I pulled the body and checked connections, all was well and the truck was responding again. I gave it some throttle and it immediately rebooted again. Figured it was the old battery or a dying cell so I swapped another also old (but balanced and all cells at 4.20) 4S pack in, plugged it all up and ran again. 5 minutes later the truck rebooted again, and then shortly went into a full on flicker-fest. The LEDs flickered on and off and the Mamba was constantly boot-looping. Now I know my batteries are old but two different packs shouldn't do this. I managed to capture a quick video of it doing this before I unplugged everything and went home. Here's that video video of the truck frozen with the lights flickering:
https://www.youtube.com/watch?v=B5TNR5H3lPI&feature=youtu.be One of the LEDs popped out in my haste to get the body off the first time the glitch happened. Should be unrelated.
Things I noticed so far:
- The reboot seemed to happen mostly when the steering servo is in motion, especially at full lock. The endpoints are set and it's not stressing hard against anything at either side of full lock. I'm using the outer hole on the Vanquish clamping horn. Not positive this was the culprit, just something I noticed.
- When I fiddle with the Mamba X ON/OFF switch, sometimes when turning it off the steering servo violently whips well past full-lock to the right, going wellllll past the limits of the link and steering assembly. When I turn it on again, it ends up resetting during the boot up process and is fine. I honestly wish the ON/OFF didn't exist.
- Powershift LEDs look to be rated up to 3S. Possible something got too hot here on 4S? They didn't seem warm during the drive and it was under 60F and cloudy with a drizzle. Still not sure if this is what could have caused symptoms like this.
- the problem persists with the LEDS not plugged in, and the JST splitter not in the picture either
- No binding in the drivetrain, Motor, Mamba X and SHV500 V2 were all lukewarm to the touch.
- The truck tipped over into a shallow creek once on a trail the day prior, with no body. Nothing got submerged, but everything did get splashed. Every component I bought is either water resistant or waterproof, so shouldn't be an issue? I grabbed it within two seconds of it happening. I'm not submarine commanding this thing, especially in its unfinished state. The truck has gotten a cleaning with WD-40 and a shop air compressor after every run.
- I'm running a TRX plug on the Mamba X with a pigtail JST accessory connector. Did this because I have a mix of TRX, XT60, and Deans packs and all my adapters go to TRX, so figured it was the most common one for now. Could it be a messy solder point causing this? I'm going over all that today to make sure, but the JST+Mamba X leads together were tough to fit into the TRX connector cleanly.
Any ideas here on where to start or has anyone had a similar issue in the past? I haven't had time to do a full inspection but will be later today once I get through some work. I plan on running a brand new 3S pack around the yard to rule out the old 4S packs.
And before all the drama we had a ton of fun with dueling TRX-4/SCX10.2 Broncos!
Mamba X
