LukeKang77
Hello everyone.
I have been wanting to do a build thread on my twin hammer for quiet a while, I just haven't had the time. I bought my hammer brand new over a year ago, and I have had it set up many different ways over the course of the past year. It has pretty much turned into my trail/basher rig, but I still drive it on a local 1/10 scale outdoor track on occasion. Well I guess I better start from the begin. Last June I discovered this little forum site call rccrawler, that opened up an entire rc world that I never even knew existed! It spurred some new life into my twin hammer and soon formed my scale addiction!
The first real mods that I did we're....
-blue monkey upright tower
-85mm Gmade XD shocks
-blue monkey rear trailing arms, single shocks.
-103mm Gmade XD piggy back shocks
-Hobbywing 80a wp Ezrun esc
-Tacon 3650 3500kv brushless motor
-HiTec 645mg steering servo
-Turnigy 4200mah 2s shorty lipo pack
-RPM 2.2 revolver crawler wide wheels, w/0ld school 2.2 Proline switch tires
-rear sway bars, and vaterra aluminum hubs
-everything else is stock.
Ran this set up for a month, and primarily drove on a 1/10 outdoor track. Defiantly found the weak points. The blue monkey upright tower would bend almost every time I took a hard crash. Smoked the Hitec servo, the shift servo, and the stock steering rack. I had to limit the front shocks a couple of mm to prevent breaking the front dog bones.
Then I decided to turn it into a crawler/ trail rig. Bought the hot racing steering rack and was completely disappointed. It bound up worse than the stock did! So I took it to the next level. I just took the entire left A-arm, driveline ,knuckle and hubs and moved it to the right side, and vice versa! Mounted the servo upfront with a custom mounting bracket, and used some traxxas slash turnbuckle links for steering links, it worked great at low speeds, but I had terrible wheel hop at full steering lock, and some driveline alignment issues at full droop.
- Changed a few things..
- new painted body
- traxxas red turnbuckles
- Axial 8 hole 1.9 beadlocks
- pitbull rock beast 1.9 tires
- solar d772 steering servo
- locked tranny in low gear.
Ran it this way for a couple of months. Wanted to change up the front end again! Changed the servo back to the stock location, and added Derwood DD steering kit. Installed the DD on to the GCM upright shock tower. I like the GCM tower, but I didn't keep it to long, it was to heavy for my track bashing needs, seemed to work better for trailing and crawling! (Kind of wish I would of kept it!)
Then changed it back to a track basher rig. Changed the front end back to stock. Kept the Derwood steering kit installed, I installed the stock front suspension, and relocated the battery into the chassis.
Added some new parts!
- Gearhead 1.9 Sixer beadlock wheels
- locked the tranny in high gear.
- Tacon 3660 4000kv brushless motor.
This is pretty much how it is now! Moved the battery back to stock location. I recently installed Sir Irie products steering rack and top plate- which is awesome by the way! My Derwood had some worn out bushings. I was suffering from very bad bump steer. Here is a list of new stuff I have done to date....
- Carter Fab and Machine body panels
- MG200 85mm shock tower- this thing is bombproof.
- RC4wd rear trailing arms
- Sir Irie steering rack
- turnigy 390dmh mini shift servo
- locked up rc 1.9 iconic SLW beadlock wheels, agile beadlocks
- RC4wd 1.9 TSL boggers super swamper tires
- VP hubs and knuckles
More to come!! Thanks for looking!
- new painted body
