I started taking the axles apart tonight and will finish them up tomorrow and will do the grease port mod while I have them torn apart and will keep you guys updated on whether the added grease helps. I also did some research on my esc today and pulled up the manual online and it says that the led light on the esc will blink when there is overheating and will also blink on low voltage and so I drove it around for a little bit until it started to stall again and looked at the light and it was just solid which means full throttle. I picked up some grease so I hope that fixes it and I can get back to crawling!! "thumbsup"
Were you actually running the truck at full throttle when you looked at the led that indicated the truck was at full throttle? - in many cases, an led pattern that is telling you that you have activated the low voltage will be happening with the transmitter at neutral with the truck not moving with the esc turned on
What do you mean the led was solid indicating full throttle? - that makes no sense in the scheme of the truck losing a lot of power (but not all of it), all of the information you've been presented with by people in this thread, and your reason for starting the thread in the first place
If you aren't going to offer specifics with regard to the troubleshooting and aren't going to put the effort in communicating your findings, then there is no point in trying to help you solve the problem - instead of finding and fixing the problem in a few posts through back and forth communications that contain the information we need to help you, it leaves those trying to help you ending up having to write post after post trying to pry information from you…information that, if I was asking for help, would happily volunteer to provide - it's common sense, common courtesy, and blindingly obvious common sense
That being said, given the lack of useful info you provided and your plan to fix your problem, I'll say this:
If the worms not having enough lube on them was causing your truck to lose power after a short time into your run, the power loss would be due to FRICTION - whether the worms are rubbing too much, are shimmed too tight, or a bearing in there has failed, the bottom line would be an increase in friction - but if you have friction issues related to the worms, the only reason that it would cause the truck to lose power would clearly manifest itself in excessive amp draw, voltage drop, etc - the sure fire, without a doubt indication that excessive friction was causing power loss would be a hot motor, battery, axle housing, or esc (or any combo of those)
You said the electronics were not hot at all - You didn't offer up any info with regard to excess heat on any part of the truck (as those that have tried to help you suggested) - do you see where I'm coming from now as to how you not making the effort to communicate, in full, what troubleshooting suggestions you've looked into and what your findings were for each item checked makes it very difficult to help you?
I can say, with damn near 100% certainty, that if you grease the worms to reduce friction, but have seen or reported NONE of the side effects that friction would cause with relation to the direct results that a high friction issue would have on your electronics, then lubing the worms is not going to solve your problems
While taking steps to grease the worms and modding the axle to make it easy to do in the future is definitely something I'd agree should be done and I think it is a smart move on your part, the fact is, if your problems were related to friction in the axles, it's a simple cause and effect situation - and if you have friction problems, it would result in some aspect of your electronics being overworked - and this, in 99% of the cases, would result in heat in the motor, heat in the esc, heat in the battery, a puffed or dead lipo cell, or heat in the wires or connectors
Now, if I'm wrong here, someone please correct me and I'll be right back in here with my tail between my legs - but, dude, if you want help/troubleshooting advice, it makes it very difficult to help you if you don't give us something more to work with - I, for one, am not going to beg you for the info
Signed,
A Slightly Annoyed mudholestomper
