losi micro trail trekker springs?
akrcguy
North pole
what springs can you use on the trail trekker i was thinking micro t but i dont really wanna buy them unless im shure because they would just go in the trash
Micro t/micro Dt springs are shorter. They can be stretched and/or spaced out. They're much softer.
I have a set of micro T desert racer shocks. (ones with the small bracket on the bottom
the large one is the trekker shock with an X-mod stretched spring on it. you can find xmods shocks and parts on ebay still.
the micro T stuff is good if your going scale. but you wouldn't want them on the stock trekker body.
same with the 1:18th Mini T, which are HUGE and I don't feel like digging mine out of a box to take a picture, they wouldn't work either.
The micro truck's shocks will work if you mount them like this:
however the trekker frame rails will be significantly more likely to bind as these shocks are MUCH smaller. as seen in my last picture. :D
You will need to make a special shock upper mount bar for them if you mount them like this too.
(note: The truck pictured is a completely custom frame, and not the trekker. although that is a trekker axal.)
edit: and yes the rear shocks ARE longer than the front for the micro shocks. but not enough to compare to the Trekker's.
8695 beaters thank you for the information and the ball stud on the top shock on the right what is it and where did you get it i need some long ones ...more travel i heard
