Losi Crawler Pictures......
I went down to the river the other day to conquer the rocks while my wife was agate hunting. About 20 minutes in i was being dive bombed by two killdeer birds...ten minutes later i found out why when i almost crawled over four camo'd eggs in their nest!
the only mods so far is a complete waterproofing with plasti-dip and marine grease + the 1.9 losi weighted bead locks. I'm new to the hobby so taking in the tips from the forum and enjoying the reads. Next week i'll head to the nearest hobby shop (+100 miles away in vancouver wa) and check out some body-shells and maybe grab another set of bead locks...We have two MRCs, & my wife is like; "I want those wheels too!"... :)
Happy Trails,
Thom
Updated info on my MRC :)
I swapped out servos and now have the Futaba S3305 as the HS did not have an equivalent HiTec 645. This one has 145oz of torque and seems to do fine.
Swapped out the stock chassis for the TCS Edge. I like it lots! Since this is a non-comp play around rig i didn't mind the extra ounce? of plastic electrical-project-tubing to protect the metal. It sort of gives it a Mad Max look :) It had a few tumbles and was none the worse looks wise so it did what i'd hoped in protecting the finish. OH, and of course the Monster Drink graphics from a couple cans of the blue version.
Swapped out for metal dif parts.
Alum. wheel extensions.
Alum. threaded shocks with added internal pen-springs to limit travel.
Alum. bead lock wheels with included weights on front (gave the extra set to my wife for her front-stock wheels on her MRC, work great).
This is taken at a nearby creek. My wife was gold panning a few feet away while i played with the MRC.
....updated with a shot of my wife's MRC with the body and wheel face-lift she did. She really enjoys crawling!
Tekin B1r, promax motor, bent links, stock pro chassis
Sent from my DROID RAZR using Tapatalk 2
Here are some updated pictures of mine. CG3 Chassis, Vendetta rear shocks with soft springs on all 4, Aluminum C-hubs, Aluminum zero Ack knuckles, custom steering, tower pro high tq digi servo, TEAM BROOD FRENZY mini motor, BWD Lower links, BWD Bomb Proof mounts, Axial 1.9 wheels with custom painted rings, Butchered Flatirons, and Proline internal weights.
Stock rtr chasis with bwd 4link servo mount and rear link mount, pro-line swampers, delrin bent links, losi threaded shocks with semi droop set up, insane motor, hitec 5645, lots of weight up front, metal pipe bead lock rings with lead in center of the wheel, trax. 8mm wheel hex's, losi front cvd's and zero ackerman knuckles
Works pretty good for bashing, twisted a driveshaft tonight on it romping :mrgreen:
guess it is time to update my pics too.
still rtr chassis
ax10 ota steering mod
overdrive mod
lowered electronics
13t pinion on stock motor
4 link rear with pro rear link plate and stock lowers for top links
battery on front y link
vr-01 beadlock wheels 3oz front, i think bout 1.5oz rear
hacked and broken in flat irons
losi bronko body
traaxas wide hexes with stubs drilled for bigger pins
cut and trimmed dog bones for more steering
ax10 servo plate
losi threaded mrc shocks front in semi droop with 5mm outside limit and pen springs, rear 5mm outside and 8mm inside limit with one coil cut on stock silver springs ( still playing with rear springs) 40wt front and rear
outbroaded shocks at chassis
2 stock 1100 nihm and 2 1400 nihm batteries
metal locker all around
stock knuckles drilled for zero ackerman
and axle cases bolted and nutted
I'm lucky enough to have 2 MRCs, one which is completely waterproofed and has been everywhere, the other which is built from the ground-up from parts into a capable crawler and semi-scaler.
The new and old together:
Night crawling :)
Old: Stock MRC chassis & motor with fully waterproofed electronics, 5800mAh NiMH system (2900mAh packs over each axle; 4 hour runtime), waterproof Traxxas servo, metal lockers F, R and centre, multi-mode 220W spotties up front and running/rock lights, Proline Flat Irons.
New: GC3 chassis, MRC Pro running gear & Integy alloy linkages, metal lockers F, R and centre, Novak Mongoose ESC & motor, Bluebird hi-torque waterproof servo, 8A BEC, 3S 500mAh LiPO for ESC and motor (30 min runtime), 2S 460mAh LiPO for Rx, BEC + steering and lights (60 min runtime), RC4WD steel beadlocks & Mickey T rubber.
heres my little trail trekker
i dont see many posted on here
Probably because this is the Mini and not the Micro sub-forum! Here is the Pictures thread for the Micros and Trekkers.
Hey guys! I just picked up this losi Mrc in a trade. I haven't driven it yet, Im really excited to see what it can do!
Its all stock other then a traxxas 2200Mah Lipo.
Here's mine, nothing major. But mounted ESC on back axle and battery on front axle, deleted center chassis plate. Next hoping to get new body and do it up different
<a href=http://s1156.photobucket.com/albums/p572/rccrawler13/?action=view&current=d35e8220.jpg target=_blank><img src=http://i1156.photobucket.com/albums/p572/rccrawler13/d35e8220.jpg border=0 alt=></a>
<a href=http://s1156.photobucket.com/albums/p572/rccrawler13/?action=view&current=d4d63bdf.jpg target=_blank><img src=http://i1156.photobucket.com/albums/p572/rccrawler13/d4d63bdf.jpg border=0 alt=></a>
