droopmodmrc
I got my rear Bead locks set to just barely pin the tire. I tested and I tightened, and then I tightened some more. Now I got it set perfect so the rears just slip right before a forced roll over from the usual rear traction bite .and when you get jammed up it acts very much like a dig. some one else try this and let me know what you think. I didnt read nothing in the 1.9 rules that says you tires have to be locked down . I bet you would raise some eyebrow when your rear tires stop spinning when your about to roll in a comp :lmao:
If you try this, make sure you tighten them up enough to still pull off your usual steep climbs. Its like a slipper clutch for each rear wheel . I like when i get a rear tire stuck now. I can just power right out and the tire will spin before anything breaks."thumbsup"
