Live Venom Creeper build today!
soon to be crawler owner, havent decided on type.
what are advantages/disadvantes of scale vs. comp. for me, sorta leaning toward scale, especally scx 10... thanks guys, good job
Heads up on saving your tires !!!
HEADS UP ON SAVING YOUR TIRES !!!
watch out for the bolts that hang below the nut on the rear most bottom of the rig, i ran some panthers (very soft) and it tore a hole easy, binding the wheel, and that was driving it in cold north idaho 20 deg or so. i imagine the stock tires will soften up much when it gets warm this summer.
quick fix : i used a 3" pneumatic cutoff wheel, (could use a dremel, you should have one of them) and cut it flush at the nut, this way the threads are saved if you need to remove it. Do a close up with the camera if you can.
I talked to Chris about this, so maybe you got shorter bolts or I am sure they will get revised in the future.
