rockhugger
I use both a 30 and 50 cal. Steel ammo cans always clamped shut at home unless I'm working with the lipos. If I'm running at my normal spot, it's usually out of the back of the car so I keep the lid off.
I drilled holes and added binding posts with a soldered deens and 5 inch lead wires inside of the 30 cal can so I can charge with the lid closed. I still need to add the balance plugs in there too. I always attend to my charging batteries, and I'm within a few feet. I also picked up a large heavy gauge steel pie baking tin to set a charging batt in for when I'm not charging in the ammo can.
I may add a few lipo sacks to the current setup just for added piece of mind and to save the other batts.
