Lil' Mountain Goat, Slackerman's 2.2 Hilux
slackerman
Reno
So after doing some more work on my buddies rig i decided to dust off the 2.2 TSL's and create a Hilux, KOH/TTC Truggy. I get bored of my build fast, but this one i can tell is going to keep me busy for some time.
Specs ill post after i finish up the bottom of the chassis and connect the axles.
Lil Run down of my Direction, I have been wanting to do a KOH/TTC Truggy, so I hacked up my lil Hilux body i had so i could use it for panels on a full custom tube chassis. Create a WB of around 12-13"s. Run my 2.2's, and finally go one step further then i did on Tims rig. (Naturally i have to have a more bad-a$$ rig LOL)
Ill post more up later, here is the pics i have so far, Only got the upper mid to rear started today.
Here is what i had to start with.
It was sad to do at first but the end result will be worth it.
Made a Sub-frame so id have a base to go from.
Testing of Panels
Start of the cab
More Progress
The A$$ End
Here She is sitting Nice and Skinny."thumbsup"
Here she sits next to another Doved yota i had bought a while back, that started my into doing my own brazing work.
The other cab over my new rig
That's what i got done today. Hope you all Like it, Toss me Comments, Questions and feed back if you'd like.
More to come tomorrow."thumbsup""thumbsup""thumbsup""thumbsup"
Looks badass. I like the narrowed cab.
And the swampers really come to life when you cut them like that, they bite that hook dirt and jump you right up the rocks like a real swamper
Thanks "thumbsup"
Update 1
Got some more time to work on it tonight. Started on the lower part of the chassis and made my way to the front shock towers, and also I tossed on a piece of solid stock for a start of a dash.
I hope to finish up the front end, Shock mounts, and start on the rear lower and shock mounts.
So here is the start of the Progress from today, bunch of pics.
Base done
Working my way forward.
One shock and frame done
Test fit
Dash and support in.
Done for tonight, test fitting of panels
Starting to gain some character to it now.
Measurements as of now.
Pics of the chassis as it sits now.
Dash main support
Stay Subscribed for more"thumbsup"
Hope to have a roller tomorrow.
Looks awsome slackerman low and mean.I really like the shock hoops coming through the hood.You really do some nice work love all your builds"thumbsup"
Update 2
Got to work on it for a few today, Ran out of cut off blades so i made it an early night, but its up on its own feet now, still have to make a rear upper link mounts, and move the rear shock mounts forward a lil bit.
Heres the pics.
Got the skid on
166354_1598795453173_1334624048_31467103_7643940_n.jpg%5C
Testing fit
Next to Tims Rig i built for him
and how she sits as of now after todays work
Might have it under power tomorrow:mrgreen:
Thanks for the Comments"thumbsup"
Quick update.
Added bent links to the rear, and put the stock scx10 shocks on for a low sitting ride. Belly is a hair under 3"
More to come tonight.
Looking good slacker, could you post up some pictures of the way you mounted your upper links with the bent link rears. I have done it to mine and it works pretty good, but Iam always on the lookout of other ideas.( My uppers are shortened and remounted higher where the frame sweeps up in the rear). Thanks
Got the rest done today so that i can take it out tomorrow and test it, make sure i dont need to do any changes, the normal bash test.
here is the pics, still have to do detail cross bracing yet, and body work but i got the main frame done.
As asked, heres the rear link mounts
and the front
She sit is pretty light, and the low COG helps out a bunch, granted no lipo, esc rx and bec are in :)
some Fresh paint for tomorrow
mounted up
panels zip tied on
unless the weather hits hard tomorrow, ill have some actions pics up, and maybe video.
Went out to prison Hill today heres a few pics i have uploaded so far.
Have more to come"thumbsup"
So after today, the rigs is AWESOME on the rocks i didnt get a chance to get any video but i got a few pics from the day. The chassis held up great, i took a few really hard falls and tumbles. ended up bending a 30% bent link into a 80% bent link, but the chassis does not have one dent or bend:mrgreen:
Here is a few more HDR pics i finished in Photoshop a few mins ago
Hope you like them, If you are around the Carson City area we are probably hitting P-hill up again in 2 weeks.
