LED light controller DIY
Awesome, I don't have any specific custom needs, but I have always wanted to get into these tiny boards. This may be a cheap starter project.
Sent from my Nexus 6P using Tapatalk
Here is the design.
Headlights get a bit brighter on engine rev up.
Brake light on at neutral throttle position and dimmer (tail light) when throttling up or down.
Signal lights.
Brightness controlled by 490Hz PWM so no blinking.
Good luck
DIY LED Controller
Before I order it seems like this programs via USB, is anything else required or recommend to get started?
Nice project. Wish I had found it before starting my own. Mine does exactly what I needed for now but if you need more outputs check out the Open Source Light controller.
That open source board could be made 1/4 the size if they used a nano or pro mini and a daughter board with mini mosfets. The Adafruit you linked to uses the same chip so the code should work with little to no mods, you'd just need mosfets or trasistors if you want to power more than 2 LED's per output. The open source project looks pretty inclusive tho, I'll be checking it out.
