Latest Mamba Micro X - external BEC necessary with direct power servo?
redrustbucket
Subscribed Member
sunny acres
As the title states, is it necessary to wire in the external BEC included with the latest version of the Mamba Micro X to power the receiver itself?
The last time I ran an external BEC was on my 1 cell Mamba Max Pro so it’s been a while. The internal ESC circuitry is always powered from the battery but without an internal BEC the transmitter would not see power unless I add the external BEC or power it directly off the battery, correct? I went with the MMX over my Mamba X to save weight but didn’t realize they were shipping with an external BEC now so I’m a little disappointed that it seems I need to add the extra BEC and wiring just to power the receiver. Receiver is a Fly Sky FS-R7P which will handle 9v input max, I’m running 3s otherwise I could power the receiver directly off the battery.
Good question. I assume they removed or disconnected the internal bec in the version that comes with a castle bec. If you only need to power the receiver, I'd go with an NSDRC micro bec that'll be a little less big/ugly than the castle.
https://nsdrcscaleparts.com/products/nsdrc-micro-bec
EDIT: Amain says there is no internal bec anymore. Definitely check out that micro bec.
"NOTE: The Mamba Micro X2 will no longer include an internal BEC unit. Included with the Micro X2 ESC will be an upgraded external 10-Amp adjustable BEC (CSE010-0004-00). This external BEC upgrade will be supplied at no additional charge."
Can't remember where but I seem to remember them not being able to get the internal components required for the BEC only. So in order to just get the ESC's out they're tossing in their BEC
