HARDKNOCKZ
Its a HARDKNOCKZ Life...
I run a bec , my steering servo would stop working when the motor was under load. Put a CC bec in it and it all went away, I was also able to step up the steering voltage! Aren't you done YET? :lmao:
Not sure why your servo would cut out with your motor under load but if a BEC fixed it...right on.
As far as bumping up your voltage...you can only put the voltage that you have available into your servo. If your battery is at 6v, the BEC wont amplify that into anything above the available 6v. If you bump the standard 6v up to 7.4, it'll only be at 7.4 as long as your battery has that 7.4v to give. But...Like I said...whatever works. I just couldn't wrap my head around the whole thing and was lookin for some input. Sorry for the slight thread jack tho. I guess I should've posted up a new thread for discussion.
J.D.
