KCRC - Kansas City Remote Crawlers -
Christmas in October! I was thinking about the servo in my mini...147 oz OK,but just barely and inadequate at other times. I remembered I got some servos off rctech in a trade and they worked and I said OK, maybe later. So tonight I got around to checking specs (had them for 4-5 months) One is a futaba s9351 194oz at 6v and the other is a s9156 which is like 340oz @ 6v!
I think I'm covered! I'll probably go with the 9351 for now and see if I like it. 33% more than I have now. I have in the back of my head that if I sell some stuff I could run a sportsman too, so the other would do well in there.
okay i have a question what is a good choice for the pinion gear for my new scaler ? still axial drivetrain 27 turn motor and stock axial spur gear . i had a 20 tooth pinion on it but it seemed to get hot fairley quickly ( yes i did get bound up several times )
Sam, I have the same setup on the Furd, but run a 16t pinion. Can run all day, and it still stays cool as a cucumber. Now I will say the Furd is probally a bit lighter then your tube frame but....
Does anyone have an old beat up or worn out XR10 body that they would sell dirt cheap? Planning on cutting it up and using it as panels for the sportsman
i've got a BJv4 coming, you can have mine when it gets here. it's not the hardline body though, it's a concepts body of some sort. i've got a couple different bodies if you want them they're yours.
Well, I'm going over to Adair park tomorrow about 12 ish if anyone wants to go over. Fart around for awhile.
edit, riv got ahold of me and said hes pretty sure its closed so not sure where to go....maybe Watts mill?
