89redranger
Got a fresh kit from my girlfriend for my birthday back in Januray. Been veeeery slowly putting this one together like I wished I had my last. All the fancy stuff.
Anywho, here's the parts list and a few progress pics. Nowhere near done...
Goodies-
-Twin Hammers kit
-Vanquish silver hood and roof light bar brackets
-Vanquish silver caster blocks and knuckles
-Vanquish silver trailing arms with Revo balls shimmed to fit and o-rings at the forward end to act as "wobble stoppers"
-RPM blue nylon Revo ends and hand polished 3/16" ti links throughout
-Ballstuds from a Traxxas Slash sway bar end link kit (TRA6895) at the knuckles to gain tire/wheel clearance, Axial thin M3 nuts (AXA1052) for jam nuts on the bottom
-Vanquish 1.9 Outlaw II wheels w/blue "Original" beadlock rings.
-Locked Up RC M3 threaded .185 hubs, M3x8 socket head cap screw wheel mounting hardware
-Axial 1.9 Ripsaws filled with CI Deuces Wild closed cells
-GCM upright tower/top plate
-Irie Products GCM compatible bell crank kit
-Hot Racing billet hinge pin brace
-Hot Racing billet clamping hex set
-Pro-Line Pro-Spec Scaler shocks: 90mm front, 110mm rear
-Vanquish silver SCX10 transmission case
-Billet Works Design (BWD) FOFF motor mount, reverse cut for mirrored transmissions
-Fast Eddy's M3x6x7 spacers
-Incision SCX10 slipper eliminator/top shaft
-Vanquish gun drilled chromoly idler gear shaft
-Incision SCX10 transmission gears
-Incision SCX10 transmission outputs
-Fast Eddy's SCX10 transmission bearing kit
-Traxxas #3956 54T Mod 0.8 spur gear
-Traxxas #3647 4mm flanged nuts- wheel nuts and used on transmission top shaft at slipper eliminator
Electronics-
-Castle Mamba X
-Castle Slate 3800KV
-Castle 10 amp BEC
-ProTek 370TBL "Black Label" servo with Exotek 25T 7075 Losi 22 servo horn (EXO1669)
Lots more to come...the parts list above will be updated as I go.
Sent from my SM-S975L using Tapatalk
Goodies-
-Twin Hammers kit
Electronics-
-Castle Mamba X
-Castle 10 amp BEC
