Fungi
I needed a project to help me design a better four link chassis for my product line. I'm making a Ford Bronco. It's a beat up hard core rock crawler. not a lot of horse power but geared very low with lots of torque. There won't be a hood. The doors will be removed with an internal roll cage. Lights and winch on front and back. Rock slider rails and rock damaged body parts. Hidden esc and battery. Rustic paint, lots of details. It's a trekker with custom stock offset rims.
Here is the chassis, currently using stock lower links, 5.00" wheelbase.
It has amazing articulation, which is tunable to decrease to desired amount.
Here is a mock up, fitting the body to the frame.
Here I marked the interior tub where the rails line up and started cutting. I only had to cut the first part of the tub, an area around the transmission, and a small square for the rear shocks.
Here the wheel base was shortened to 4.875 but the lower links were not shortened yet, so it's a little jacked in the back. After the pictures I got the wheelbase down to 4.750" but may tweak it down a bit more than that. It is semi droop floating about 1/4" from full droop.
Please comment, and thanks for watching.
ps the frame will be for sale in a week or so.
