Jeep YJ CC-01 build ordered!
ashman
Germany
Well I am going to be starting my second CC-01 build this month. I finally finished my other scalers to my liking and am gonna build up a simpleton. Nothing fancy. The parts I ordered:
TAM 84071 Jeep Wrangler Kit
35T lathe motor
Hitec 645MG
CC048 GPM steering
Rubber sealed Bearings
M-Parts for rear bumper and highlift holder
G-Parts Gear Part Tree to lock both diffs (I know I could've wedged the bevel gears with one from the rear but anything worth doing is worth doing right.)
I am probably going to remove the brick on this one never did on my pajero/bronco below. My bronco started life as a Pajero and turned into a bronco before the bronco CC-01 and unimog existed and while the jeep was disco'd. Also gonna try the pajero wheels and tires on the kit first. I have already started soaking them in simple green, I hope they soften up. I never used them on the Pajero, It got the integy wheels and Mud slingers from the get go. May move to 1.55 steel spokes and MT MTZ's later.
Update finally started getting parts. All I am waiting on is the parts for the front locker. Also looking for paint options. here in Germany tamiya paints are high dollar or Euro rather. Will any automotive lacquer due? They have some brand in Toom (German Hope Depot) labeled RACING it says its a lacquer based paint?
The mini man cave build area.
Parts, yaaaahhhhhh.
Rear bumper part tree.
Thought I'd add a pick of my current collection and a pic of the micro crawlers and micro course.
Nice Bronco! Will be tuning in to see how your build goes. You have inspired me to try and build my son and I a small little crawling area in the garage, I like the table idea. Thx
Thanks, for the comments. My crawler course was all scrap board, cardboard boxes , packing foam, paper machete, and plaster cloth. Best way to build one. Don't plan it at all. Just throw it together. Oh and flexstone paint.
Nice collection you got there:thumbup:
If you're wondering how MT MTZ's look on a Wrangler...here is a pic of my second Wrangler with them on 1.55 steelies. I think they look like a great fit and give it a nice stock look. Also keeps the cog down since they aren't tall(these tires are small) They won't crawl over everything but they do work quite well depending on terrain. I just took it for a shakedown run the other day on some smooth rock with just a bit of a rough texture to them. They worked pretty good on the stuff and I'm happy with them. They will rub the fenders a bit when you get in a really tight bind but it's gotta be a really tight bind.
Edit^^^-I kept the foams out of them as well and no weights. The tires have a nice realistic feel, handling and flex over terrain well.
Well I started working yesterday, but only got as far as removing part of the brick. I wanted to keep the stock front body mount, so I cut the brick just under it. Then I spent about an hour sanding smoothing and cutting some black styrene to fill the gaps back in. I have a pic I'll post later. I have no intentions on body lifting this guy so, removing the front brick completely wasn't needed in my opinion. I will probably still build an aluminum front skid later to add some scaleness and protection. I am definitely leaning more and more towards the MTZ's and black or white steel spokes. This will be a mud, sand, grass, and water vehicle more than a crawler. I have two SCX-10's for crawling, even with the 1.55 mud thrasher's on my cherokee, it still crawls like a champ. The Dingo has the stock 1.9's and tires and rarely do I have any issues there either. I think the MTZ's are very close to looking 32x11.50r15 ish. I'll use the stockers for a little while but the purchase of the MTZ"s is inevitable.
"railripper" like the pics from what I can make out, kinda fuzzy!
So no foams, did you drill an air hole in the wheels or just leave them sealed by the beadlocks?
That course is sweet man "thumbsup"
looking forward to see how the jeep looks, i like the bronco 8)
Thanks scorpion ax-10, I too have high hopes for the Jeep, LOL! I miss my old micro course, it was larger but, I knew it wouldn't make the move from Utah to Germany. If you look at the cardomain website where I am hosting my images you can see my old micro course.
Ashman-I didn't drill holes, just the beadlock sealing the tires. No need to drill holes as that will make the tires look flat with no foams. Sorry about the pics, taken from my phone and the lens has pretty much bit the bullet. There's a pic of these tires on the rc4wd website. Go to 1.55 tires, click on the mtz's and scroll to the bottom of the page, they have the tires on a cc01 Wrangler as well and that helped me seal the deal on them.
The tires are a pain to get on steelies. I used a bolt, piece of servo horn amd nut to clamp the wheel together so I can mount the tire. There's a how to in the tires/wheels section I believe. Looking forward to how she comes out:thumbup:
Decided on color's Today. I got to thinking, I had a cousin that had a YJ that he dearly loved until he totaled it. Don't remember the exact year, but it was an islander, like the one below. So in Tribute to
Samuel Aaron McCullough 07-Jul 1980 - 30-Aug 2002 R.I.P.
The Colors:
Brick Removal:
End Goal for paint colors:
Chassis is together got some pics up. Ball bearings installed, did the standard clearencing on the front hub carriers, installed the GPM aluminum steering, clearenced the two steering notches in the front skid, rounded off the front of the lower rear four link arms, mounted my axial servo arm drop links on the rear shocks, and just generally took off the low hanging fruit from the bottom that just isn't needed.
Started working on the body. Carved off the side marker lights, and carved out the offroad light mounts in the grill. I Also removed the CR-01 body mounts. Trimmed the spare tire cover to fit over the CR-01 rear bumper as well. Started sanding the molding lines. Soldered on replacements for the tamiya plugs.
Front Diff Locked
Front Skid Clearancing
My Axial servo horn drop links
Finished Chassis
Started working on the islander graphics. Absolute pain in the a**. We shall see. Drove it alot last night, the little thing is awesome. The 35T motor to me is perfect scale, yet still has torque, and punch power galore. Yes I was drifting across the living room tile, and cutting donuts like a teenager in a highschool parking lot. Probably gonna keep the tires and wheels for now and get some G-made RH-01 hubs to help the look a little.
Looks real good, love the Islander theme. great job on the paint!
you have ispired me to build another one I think
Thanks, JB
I like your mud and water pajero.
The islander theme, was in remembrance of a good friend and cousin.
Here are the final pics, the islander graphics aren't to 100% scale or a precise match but, they are good enough for me. If I had a better place to get supplies over here in Germany, they might have been better.
