After completing the assembly of the transmission you put it on the skid plate. The skid plate does some of the job of holding the transmission together. There's a nice interlocking design between the standoffs on the transmission and the skid plate. Standard stuff, but everything fits nicely.
This is where I noticed the first design fail IMO. The motor and pinion cover is held on by three screws. You can't access the lowermost screw while the transmission is mounted on the skid plate! This typically won't be a big deal, but if you ever need to check gear mesh you're going to have to pull the trans off of the skid plate. This isn't a huge deal and it may be a non issue for some, but I've checked or adjusted gear mesh more than once. I've also changed pinions on more than one occasion. In this case it's not a simple affair. As our Russian QC inspector would say, "Me no like."
After the transmission assembly is on the skid plate you next install the dig servo. The mounts are small, spindly pieces of rubbery plastic. They allow way too much movement of the dig servo. These mounts plain suck. I hope we get an aluminum upgrade sooner rather than later.
But even if we had rigid dig servo mounts the skid plate is also way too flexible. I'm not a fan at all. The junk dig servo mounts coupled with the flexible skid leads to inconsistent operation of the dig. This little servo should not be able to flex its own mounts and the skid plate this much!
The dig servo mounts need a redesign of different plastic compound and the skid needs either a different compound of plastics or some reinforcement ribbing or something.
Once the skid is screwed to the cage chassis that should help stabilize it, but I've never seen a skid this flexible.
The servo saver has no business being here IMO. I want to find an aluminum horn that is short enough to work for the dig. If anybody knows of one please let me know!
Next up is the Wildboar driveshafts. The manual is really lacking here.
It even shows the driveshafts assembled out of phase! Rich touched on this in the unofficial Capra thread and a revised manual is supposed to be available today.
These driveshafts are standard Axial stuff, but hopefully they are made of different plastic to be more twist resistant this time around. I was hoping for a redesign of the driveshafts. I don't see any need for the sliding center section. This could be built into one of the driveshafts halves, something like Traxxas has. This would prevent that center section from popping out and getting lost on the trails.
Now you might say the center section shouldn't pop out if the driveshafts are the correct length. That may be true, but I don't think we got correct length halves in this kit. I had both the front and rear center, splined section fall out while moving the axles/transmission/links/driveshafts assembly. I didn't have any Axial Wildboar parts at home or I definitely would have made some changes.
Assembled per Rich's markup drawing.
Next up is assembly the axles to the transmission via links and driveshafts, but I don't like this big spider of a thing flopping around on my bench so I save that step for more towards the end.
Next up is the cage. There are a lot of pieces and a lot of screws so either get your electric screwdriver ready or be ready for arm pump. The good news is that it is made from rigid plastics. It has an odd, dusty, matte finish on it.
Once it's assembled, even partially as seen here, it's a very rigid structure. Me like!
Before I could assemble more of the cage I needed to paint which is my absolute least favorite part of building RCs! So let's continue onto my second least favorite...
Time to build shocks. If you ever built old Axial shocks you know you wasted your time because the oil would leak out anyway. Horizon, on the other hand, tends to make really good shocks and with the new design I am hoping for a lot of improvement! They certainly can't be worse.
I knew that I wanted to add internal limiters to the shocks to drop the ride height after seeing other builds. On a rig like this I wanted the lower links to be parallel to the ground. After doing research on here, the Facebook group and asking questions I decided on 5mm internal limiters.
I realized I did not have any fuel tubing at home which I typically use for limiters. So I set off to find plastic spacers. I found this old Axial parts tree with a variety of parts including their plastic hollow balls. Hmm...
It turns out that trimmed hollow plastic balls around about 5.6mm which falls right near the size of the limiter I was searching for. I finally found a use for these junk, plastic balls! And cutting them and making use of them on the new Axial is kinda my slap in the face to the Axial of old.
:lmao:
It's not that serious. I just thought it was funny.
There seems to be a new trend of using super thick shock oil and I don't quite understand it on crawlers. Is it their way of trying to gain more stability from the soft suspension? I'm not sure, but it doesn't make sense to me so I'm not trying it yet.
Axial supplies 35 weight silicone shock oil which is always a good start in my opinion so I will be using it for this build.
I really wish Axial would have upgraded to X-rings in the shocks instead of o-rings. X-rings have twice the sealing edges while having less stiction. It's a win-win so hopefully they make this move soon. I thought about using Traxxas X-rings, but instead I stuck with the stock kit o-rings. I want to see how well the Horizon flavor Axial shocks work as designed. I lubed up all of the o-rings with greens lime.
Bleeding emulsion shocks with bleeder caps is easy - so easy that it feels wrong. Emulsion shocks are much easier to bleed than bladder shocks for me. You do lose a lot of oil in the bleeding of these shocks and I often think I'm doing it wrong. But all of these shocks rebound about the same so I'm going to count it as a win.
Had I known the shocks would have been that easy I may not have not have procrastinated.
I do wish they would have designed a recess for and included an o-ring seal for the bleeder screw. I am concerned this will be a leakage spot.
They did include captured spring retainers this time and that's a huge win. No more losing spring retainers in a bad rollover out on the field and having to gangster lean for the rest of the day.
The aluminum shock bodies are also much higher quality than the old Icon shocks. These shocks look good and hopefully they perform and remain mostly leak free.
