martybauer31
Hi all, I have been lurking and reading the forums, trying to figure out what I want to do. At the moment I have a Team Associated SC10, it's fun to bash, but admittedly it's on the fast side for me, it's pretty much stock and I know there are things to do with it, but the Bomber and it's apparent ability to do a little of both is appealing. We have a weekend place just east of the mountains up here in Washington and our property is prime for me to set up a course where I can let it run a bit and crawl too.
I'm thinking I'd like the ratio to be around 60/40 to 70/30 bash to crawl, I don't need insane top speeds but it would be fun to crank it up now and again.
I have listed items I was thinking to start with, I know there's a million ways to do it so I listed what I was looking at below. The big ones are I want to make sure I have the right motor (i'd like to go brushless sensored), esc and servo if I were to go with the 2 speed conversion.
I'm open to being talked in or out of anything and thanks for the assistance, just reading through the forums has been eye opening to what you can do with these things.
Vanquish sway bar https://www.amainhobbies.com/vanquish-products-currie-antirock-sway-bar-silver-vps07691/p451103
Incision Links https://www.amainhobbies.com/incision-rr10-bomber-1-4-stainless-steel-link-set-8-incirc00060/p496054
Vanquish trailing arms https://www.amainhobbies.com/vanquish-products-yeti-trailing-arm-2-black-vps07350/p402624
HH Trailmaster BLE Pro ESC https://www.amainhobbies.com/holmes-hobbies-trailmaster-ble-pro-esc-waterproof-hhbtmbleprowp/p492874
Castle Creations CC BEC Pro 20A 12S Switching Regulator TowerHobbies.com | Castle Creations CC BEC Pro 20A 12S Switching Regulator
S420 servo 420oz-in v4
or HH H500 servo HV500 Servo - Featured Products
Axial Aluminum servo horn https://www.amainhobbies.com/axial-racing-aluminum-servo-horn-25t-axi30836/p221417
Axial 2 speed conversion kit Axial Racing - 2-Speed Hi/Lo Transmission Components
or SSD 2 speed conversion? https://www.amainhobbies.com/ssd-rc-yeti-2speed-transmission-conversion-kit-ssd00041/p498725
Tekin ROC 412 4-Pole Sensored Brushless Rock Crawler Motor (3100kV) https://www.amainhobbies.com/tekin-...s-rock-crawler-motor-3100kv-tektt2600/p247702
or Holmes Hobbies 2200KV Puller Pro BL 540 Standard - Puller Pro Series - Brushless Motors - Motors
Thanks!
Marty
Thanks!
Marty
