HahnsB2
What have I got myself into :shock:
This thing is massive, but I had to have one after seeing a few builds around here, most notably Szczerba's two builds.
I'll probably start picking up the parts for it after xmas. I have a set of stock AR60 housings, and some stock gears laying around, just need the shafts. Plan on using a Wraith skid with wraith length links up front and perhaps Yeti length in the rear, so Bomber (14.75") wheelbase. I have a spare HH BLE ESC, Trailaster Pro 3300KV and a HV400 servo for it. I'll probably gear the hell out of it since I imagine it's gonna be heavy.
I have a set of Axial Trailready beadlocks, will probably use the R35 Ripsaws from my Wraith when I get Pitbulls for it.
Will probably chop the cab and make it a single cab. I want a different color and black grille too. I will for sure be chopping of the little fender flares.
Ideally I'll build a 1 or 2 rig gooseneck to pull behind it. It should really have a winch or two as well.
Specs.
Chassis: Scratch
Wheelbase: 16.5"
Axles:
SSD Diamond Center rear, SSD Diamond front, with Delrin pinion skids
HD UD Gears
GripFab Spools
Vanquish Link Mounts
Vanquish Scale Cs, SSD Scale Knuckles
Axial universal's
Self made steel copies of VP Ti steering links
Transmission:
RRP idler and lower gears
STRC motor mount
Junfac Front driveshaft
MIP Yeti Rear shaft, extended
32p gears 8/60
Shocks:
93mm Gmade Aeration shocks, hard springs front, custom stiff springs rear
Homemade swaybar setup
Links:
Vanquish Ti 160mm links for rear
VP Ti Wraith front links
Electronics:
ESC: Holmes BLE with MMP fan
Motor: Holmes Puller Pro 2200KV
Servo: Hitec 7950
BEC: CC
RX/TX: Tactic TTX300
Wheels/Tires/Foams:
Wheels: VP Incision 307 Methods
Tires: Pitbull Growlers
Hubs: Incision #4
Foams: CI Deuces Wild
Specs.
Chassis: Scratch
Wheelbase: 16.5"
Axles:
HD UD Gears
GripFab Spools
Axial universal's
Transmission:
STRC motor mount
32p gears 8/60
Shocks:
Links:
Electronics:
Servo: Hitec 7950
BEC: CC
Wheels/Tires/Foams:
Hubs: Incision #4
