when i was in the market for tire foams i looked at everything on the market and i dident like the options out there the airfilled sealed tires sucked they bounced like mad and they got holes in th3 sidewall in a run or 2 and dident hold air anymore then its back to foams
i stuffed everything i could think of inside the tires i cut up tire foams i tryed foam BBs it seemed like a good way to go but that was a mess i wouldent wish on anyone then i thought put them in some kind of tube
that just seemed like a problem waiting to happen
then i started thinking abou5 inner tubes but then were back to airfilled and the issues that brings
then it hit me
why not just stick a small tire in a big tire simple and easy
so i tryed it
i took some old over cut worn out ripsaws and stuffed them inside my jconcepts ruptures and instantly blew me away it litteraly doubled the capabulitys of my crawler it litteraly crawled straight up a rock face one spot is over 90° the rig literaly grabed on to the rock and climbed up so ok this is a redcat it dosent take to much to make it better but still thats a huge inprovement
then i stuffed my old austars inside my hyraxs and put them on my heavy 1/8th scaler it weights around 20lbs and although the results werent as good it was definitly a noticable improvement over closed cell foams that were in the tires before and were the rig roled over before it would drive right through with out issue and the turning was better also
the itss worked better than tire foams on every rig i tryed i got better grip better sidehilling and better steering but thats just me
there are several ways to tune this system
you could seal the inner tire to the rim and vent the outer tire
you could vent both inner and outer tire
you could very the size of the inner tire
you could use different compound tires inside
you could use tunning rings between the 2 tires
you could even run foams inside somewere
this is very crude there is alot of room for improvement most of my testing is done using cheap chinese tires inside of good tires but you could cut and shut just about any tire to any size if you realy wanted too
my hope is some one will develope a product that fits the available tire sizes and provide a better shape to conform to the outer tire
im just planting the sead with the hopes that others will take the fruit and and turn it in to a viable product
im sure im not the first person to do this there isent realy anything new here
indont see any way to make money from stuffing 2 tires on 1 rim but if someone can make something more aplication spacific then by all means make as much as you can i reserve nothing for anything about anything here in this post
i dought this will be a option for the comp crawler guys cause there is a fair amount of extra weight but for scalers in my opinion is the best thing since puting a crawler between 2 slices of bread
so to whoever read this far down give it a try im sure you already have the extea tires laying around and post up your opinions and dont worry about hurting my feelings lol
im working on a video on this set up it should be about a day or 2 but its not rocket science
then it hit me
so i tryed it
