Rumpelhardt
I think this might have gotten a little out of hand but it's almost done. Next project is going to be a ready to run with upgrades as needed.;-)
Axial
1/10 Yeti kit
25t aluminum servo horn
machined aluminum adjustable motor mount
Hobbywing (originally bought a little over a year ago for another project)
XERUN SCT Pro esc
3656SD 3400 kv sensored motor
Vanquish
Incision 2.2 Method beadlock wheels
Incision #5 hubs
trailing arms
titanium upper links
Currie Antirock sway bar
front knuckles
caster blocks
SSD
Wide Diamond centered rear axle
Yeti 2 speed transmission conversion kit
STRC
aluminum bell crank
Wraith/Yeti bottom shock/trailing arm mount
Robinson Racing
64t 32p Heavy Duty slipper
one piece X Hard output gear
one piece X Hard idler gear
Pro-Line
Traxxas Slash rear Power Stroke shocks
Yeti rear Power Stroke 5" shocks
MIP
X-Duty rear drive shaft
Lockedup RC
FI spool
Crawler Innovations
Deuce's Wild 2.2 tall single stage foams
Pitbull Tires
2.2 Rock Beast II tires
Pending funds
Axial
machined aluminum 4 link mounts
machined aluminum sway bar clamp
machined aluminum upper shock mount plate
Robinson Racing
1each 12t, 13t, 14t extra hard 32p 5mm pinion gears(already have 15-20 and I like to have options)
STRC
aluminum heat sink motor plate
And a few other thing I'm sure I forgot to list
Axial
1/10 Yeti kit
XERUN SCT Pro esc
Vanquish
Incision #5 hubs
trailing arms
front knuckles
caster blocks
SSD
STRC
aluminum bell crank
Robinson Racing
Pro-Line
MIP
Lockedup RC
FI spool
Crawler Innovations
Pitbull Tires
Pending funds
Axial
Robinson Racing
STRC
