Well I've been watching the Gmade Gom from the sidelines long enough, I ended up finding a new kit on Ebay for a decent discount, The guy selling them seems to be auctioning off one at a time, if you're interested here's a link
I started off by rounding up a ton of parts mostly from RPP:
Holmes Hobbies Torquemaster BRXL
Castle Creations 10 amp BEC
Spektrum SR415 receiver and Spektrum signal voltage boosters (to make the Hitec servos play nice with the Spektrum receiver)
Gearhead BEC RX bypass adapter
Traxxas Titan 21t brushed motor (lightly used in my TRX-4)
I rounded up some Hitec servos, HS-7950TH for steering, D645MW for the shifter (chosen because its the least expensive programmable Hitec servo)
Vanquish 24t servo horn
JConcepts 2.2 Scorpios (6" tall)
I'll be reusing an old set of Incision Method wheels (MR307, black anodized)
Crawler innovations comp cut double deuce foams, medium up front firm in back.
some Gmade Gom upgrades, front upper link, rear lower links (trailing arms), Sway bar for the back, rear shock brace, Junfac driveshaft, rear secondary shocks, front CVA axles, Panhard chassis and axle mount, slipper clutch plate
I cleaned up in preparation for the incoming mess that I knew would be epic
So far I've got the Axles, tranny, transfer case, links, the electronics all soldered up, and a tiny bit of the cage put together.
I always like to see the tires mounted up so this was one of the first things I completed. I've never tried any JConcepts tires so I'm curious to see how they do, just by feel they dont jump out as being as soft as Pitbull or Proline tires, again thats just my impression from touching them.
I hooked up the electronics last night and started to setup the shift servo. I got it to match the specs in the manual but in action its pretty spotty, it tends to get stuck between high and low gear and once stuck it tends to stay stuck instead of popping in place after playing with the throttle a bit like most other setups I'm used to.
I did the washer mod on the shifter cover but that alone isn't solving the spotty shifter. I plan on replacing the servo saver with a normal servo horn and dialing in the EPA.
On my brother's Gom we had eliminated the servo saver, dialed in the EPA, used some different length springs on the shift forks and the washer mod on the shift cover. I'm going to try these things one by one in an effort to pinpoint what the solution might be.
The springs we used in my Brothers build were pen springs cut to length (stock is the black one on the right)
I'm curious to hear whether folks are using the servo saver on the shift servo or not.
Oh and watching the KOH has made me a lot more interested in a race livery as opposed to my usual plain Jane paint jobs, I'm yet to nail down a design but it will be white, silver and black
A few things I plan on doing eventually are to make a dust cover for the shift channel/slot and to come up with some sort of support structure for the rear winglets that stick up in the back, I've seen how one good roll can destroy these
