tedmo
I'm implementing the RC4WD over/ Under-drive transfer case in the stock skid plate of the Venture. It is a questionable implementation because of the driver side output of the transmission dog-bone going into the intended output of the rc4wd transfer-case which causes a 1:1 drive to the rear axle and an overdrive to the front axle. I have Tested and fried the stock motor as a result of the overdrive causing to much load for the motor to push. I am going to try changing the stock (rc4wd transfer-case) gearing to the smallest ratio and increase the ratio as I tune the drive train. I replaced the HPI motor with a $18 Holmes hobby 35T brushed motor.
