Jeepial
I have said this same thing a couple times!!"thumbsup":mrgreen:The tires worked great, I on the other hand sucked.
thanks for the idea with the dremel.....did mine the other day! Took no time at all. two "thumbsup""thumbsup" for you!
On the front tires I did all the solid lugs, but on the rear I did the right, center and left lug, then skipped a set of them and then did the right, center, and left again.
A razor blade works great. The only isue you can run into is tearing chunck out of your tires on nasty rocks. Works good on my real vehicles also
How much time did you put into a set of wheels?
:shock: What REAL vehicles are you using a razor blade to sipe tires on?
I put about 10 minutes into each tire.Taking your time is key to getting good results.How much time did you put into a set of wheels?
This is geat for Rovers, since they already have the lines. makes them last longer.
I have had the thought,but as soft as most comp tires are,I would think that it may cause the carcass to rip,or even rip off lugs.So I just never tried it.Has anyone tried cutting across the tires ? That is the way the tire shops do for full size tires for more traction.
Would siping HPI rock grabbers be worth it
Yea I call BS too. Misinformation in so decent a thread is such a damn shame to see.
People have been using razor blades and hot knifes for years to sipe swampers, boggers and many other tires for grip on rocks and ice for many years. What PLANET you been living on?:shock: What REAL vehicles are you using a razor blade to sipe tires on?
