_Ben
I'm planning to either build a new rock racer/crawler or upgrade the electronics in my RTR Rock Rey, but I'm confused about how to read the statistics of the various electronic parts.
Here are the specifics: I've read that Savöx Servos tend to draw a relatively large amount of current, and that you generally need a BEC for them to work at full efficiency. So let's take this servo as an example. It draws 7.4 amps according to the technical details.
However, A 30c, 5000mah battery could handle an output of up to 150 amps, right?
All the servos I've looked at, from ProModeler to Hitec and Protek, seem to fall within +- 5 amps of that, which seems like a tiny variance when compared to 150 amps.
So, naturally, I next wanted to figure out how many amps the rest of a hypothetical set of parts would draw. If the rest of the system's peak draw + the Savox's draw at peak load was > 150 amps I'd need a BEC, right?
So I tried using this formula with this Castle Motor and ESC.
The formula says w = (V - R * I_0) / Ke. Most manufacturers don't seem to publish resistances for their motors, but some forum posts suggested 0.0005 or 0.0008 ohms as a good estimate.
However, when it comes time to use the formula, I often seem to get nonsensical numbers. For example, if I plug in the stated maximum speed of that motor (60,000 RPM) I get a negative number for I_0.
Also, intuitively I would expect that a higher resistance would lead to more current being required to achieve a particular RPM. However, it seems that the opposite is true of this formula.
Given how hard it's been to figure this out, I'm guessing that this isn't actually the right way to go about picking parts or determining if I need a BEC. How do people actually go about determining what sort of electronics they need in a crawler without buying them first?
