AxRub
Sorta complex wiring below, please stick with me. If you are familiar with BECs and receiver by-pass wiring, I could use your help. I don't really want to have to explain the by-pass wiring if I don't have to - it's all hooked up as it should be and works.
The problem - A SMOKIN HOT WIRE!
Immediately before I switched to the HW 1080 and Holmes motor below, this exact setup was performing 100% flawlessly with a mamba micro X and Castle 1406 2850kV combo. All I switched was the ESC motor combo.
The setup:
- HobbyWing Quickrun 1080 ESC -- new
- Holmes Crawl Master Pro 540 13t
- Castle 10A BEC
- Holmes RX bypass adapter - this https://holmeshobbies.com/electroni...ssories/holmes-hobbies-rx-bypass-adapter.html
- Protek servo
- Spektrum SRS6000 RX
- two Dimension Engineering PicoSwitch relays - https://www.dimensionengineering.com/products/picoswitch
The relays and BEC get power and ground from an adapter that inserts between the battery and ESC plug. One relay controls an axial light controller, the other a light bar and two 5mm LED rock lights. They are switched on and off with the transmitter. It's kind of cool.
So I switched to the HW 1080 and Holmes motor, motor on the bench, not even connected to the trans, plugged everything in to check it, the motor kind of spontaneously, erratically ran on it's own for a second or few, and there was a tiny puff of smoke from around where the ESC RX wires go in. It was tiny and quick, I didn't see exactly where it came from. Noticed a bit later that the insulation on the ground wire of the 3 wires from the ESC to the RX was pretty significantly melted.
After all this, I put it all back to the Castle setup and the rig again runs flawlessly.
I then connected up the HW 1080 to a new Spektrum SR515 RX, a Savox servo, very little use, same battery, same CrawlMaster Pro motor and, at least on a bench, it works flawlessly. So hopefully the smoke was the wire and there is no internal damage on the HW1080 ESC. Still questioning if I risk it in a rig. Maybe a rig with no body.....and a fire extinguisher near by.....
So I figure the issue is somehow with the BEC and RX bypass, or possibly the relays, since that is really all that's different, but I can't figure out how it's an issue with the HW1080/CrawlMaster motor combo, but not with the Castle brushless combo. The HW 1080 is not happy with something about the wiring, is my guess.
Any ideas?
Thx.
The setup:
- Castle 10A BEC
- Protek servo
Any ideas?
Thx.
