saddlesore
Need some Holmes Hobbies ESC help from experts out there.
I broke down and bought a HH Trailmaster BLE Pro ESC for my rig. Installed it and paired it to my radio and programmed it using Castle Link. I have it hooked up to a 4068 size 2400kv sensored motor geared with an 18t pinion since its the only size that will work. The motor can is so huge that running a smaller pinion would be impossible.
The ESC is programmed with default values except i changed the drag brake to 20% and BEC to 7.0v.
I noticed that when the car is idle for 20 seconds the ESC blinks and beeps. Is this normal? Also i noticed cogging when running with my 4s battery (35c). The startup is not smooth at all. When i run it w my 3s battery (45c) the startup is much better and no cogging. Can anyone recommend a setting that would eliminate the cogging with my 4s battery? Also whats the deal with the beeping at idle?
thanks in advance!
thanks in advance!
