A lot has changed in 5 years for me.
I bought myself a trail/scale crawler. Which I was never planning on doing.
But a friend got a Trx4-m. And I always liked the TRX4, but it was too expensive for me.
But this one seemed like a good compromise.
However, Traxxas wouldn't be Traxxas if it wasn't Traxxas.
I wanted to have more control and a better remote than the stock stuff.
So I bought myself a Hobbywing EZRun A2 combo pack, which I thought would be a perfect plug and play replacement.
However it appears I was too positive about the outlook.
Has anyone done a conversion like this?
I bought it because it was smaller than the standard motor and I have a lot of Hobbywing combo's in other RC's.
Apparently the motor has a smaller shaft at 2mm and a longer shaft (which isn't a real problem).
But the screw holes are also bigger than the traxxas screw holes.
So the problem I have is, I need a pinion gear with grub screw that fits a 2mm shaft and is max 5mm long.
But I also need screws which are big enough but aren't too big to ruin the gearbox all together.
Is it worth the hassle or are there easy fixes?
edit: I got screws that fit. Just need to drill out the holes. https://ultimateracing.ch/articles.php?id_article=1000019238
and I found a pinion that would work, but it's in the US and I'm situated in Europe.
It's €20 for shipment of a €5 part, not including the import taxes.
https://moforc.com/products/mod-4-steel-pinion-gears
edit2: i found another one that might fit: https://mini-zshop.nl/product/atomic-mrz-up24-11-hard-coated-64dp-pinion-11t-mrz/
according to this it's the right shaft diameter:
https://www.wolframrc.com/product/hard-coated-aluminum-pinion-gears-64p-2mm-shaft-atomic/141
Edit3: I'm ordering a different system which will be just plug and play.
I hate traxxas so much. The pinion is one of the only sizes which you cannot find in that mod/dp with 2mm shaft and 11t, they'll just do anything not to let you change their stuff.
Can't return the other system since the shipment is going to cost me 16euros, which is almost half of the total systems cost.
Let's just say this is the first and last traxxas I'll ever buy.
Edit4: After a good nights sleep, I'm going to try the pinion from the mini-zshop. We'll see if I can make it work
