So I accidentally ordered the wrong motor for a rock racer build I'm doing and am left with this, the Hobbywing AXE 550 2700kv. So, stick it on ebay or stick it in the Sendero....
Obviously, it's going in the sendero.
Aside from the difficulty in finding a 48p pinion with a 5mm shaft, the motor fits easily enough. Xmas post though means the 18T 5mm shaft pinion I found online is taking an age to get to me.
TBH, I didn't give pinion size a lot of thought. Just went with a straight swap for the 3.175mm shaft 18T that is stock in there. Curious though, has anyone else tried the AXE 550 2700kv and what size pinion gear did they settle on?
At 18T, is the Sendero likely to end up faster, slower, overgeared, undergeared, overheated....? I really should have thought of al this before installing
Cheers.
Cheers.
