Have tech questions? Will answer.
I'm sure we will figure it out :) send an email to warranty at holmeshobbies.com with the info and it will be easier, or use the contact us form on the website
Thanks! I actually called earlier and had a super helpful fella get me sorted out. He said I'm 3rd in line to have my servo checked out!
On another note, I'm dying to get back into a Crawlmaster. However, I'm torn between your options! My rig is almost right at 5lbs on the dot. What would you recommend John? This will be connected to a Mamba Micro.
Puller 400 w/ 5 slot
Puller 500 w/ 5 slot
Crawlmaster Magnum
Custom 540 w/ the 5 slot
Crawlmaster Pro
What is different about the "custom 540" from a regular crawlmaster pro?
Will the Puller 400 have enough power for a 5lb rig?
Is the magnum to much motor?
Oh and what is the lead time on a custom motor? SInce I'm running TRX-4 gear on my All Time Low I'll need a reverse rotation motor.
"thumbsup"
Glad you love the motors! We will be adding active freewheeling and drag ramp on the next firmware update of the BRXL and BR mini, if you are looking for other options.
Could you, or someone, please explain active freewheeling and how it impacts crawling?
In older esc's when you went down hill the drag break was either on or off. So if your drak break stops the car 100% when you gradually apply throttle it will suddenly release. The motor being under power Will not slow the car down.
Freewheeling allows for the drag brake to be applied even under throttle. This allows you to maintain a super slow decent even with a 100% drag brake.
Excellent! Thank you! "thumbsup"
Crawlmaster Magnum
Crawlmaster Pro
"thumbsup"
Custom pros listed in stock are ready to ship, unless you request a true custom which is 2 week lead time.
I would choose a custom pro or puller 500 depending on if you want to shed weight. Custom pro vs Crawlmaster, custom pro has heavier gauge wire for more torque and power, and also typically has a skewed arm for smoother startup
So happy to hear this. I also wanted this feature and was looking at the 1080 because of it. But I REALLY wanted to run all Holmes electronics and I wanted the best possible control from my Crawlmaster Pro.
Since Holmes Hobbies got that new Dino, I have Ben curious about how a high turn higher voltage motor compares to a low turn lower voltage motor which end up having the same max rpms. Could you post up some Dino charts and a quick summary of the results? Like a 45t on 4s vs a 27t on 2s. Or better yet, make a video!
That's the plan I have for the next big tech vid. Its turning into quite the video, gonna be long. I'll have a lot of time just running the dyno to prep.
That's awesome new! is there a way that you can change the gearing on the dyno to test both motors on 3s but with different gearing? or does that mess up all the calculations. These questions get asked so often about best motors for crawling and videos comparing the turns would be helpful.
There is so much more to it than selecting a motor that is the right speed for the stock gear ratio when you have the ability to change voltage and gearing.
personally I like to get the fast motors and gear them way down. I like my 100:1 Crawlmaster 550 10T on 3s, but I don't know that that is the best way.
I can change the dyno flywheel weight, which is effectively like taller gearing.
Are they calculated on how different they are. Like one is half of the other one? Well I suppose if they aren't in could be calculated by using the same motor, on each wheel.
I want one, just don't see that it would get much use after a Month or so. Probably should sell some other toy I don't use any more and get one though. Resale might not be terrible on them.
Are there any seriously adverse effects of giving the trailmaster sport motors a douche with WD-40 occassionally?
Sent from my SM-J727V using Tapatalk
WD40 is a no no. I rarely use it and on motors it would just cause dirt to stick. Also might have other negative effects that people with more brains than me could tell you about.
What about rubbing alcohol to to clean motors, then lube the bushings. That's how I broke mine in. Alcohol was to dry up the water I think to reduce corrosion.
John, question regarding brushed motors and their rotation direction. If a motor is ran at 0* timing does motor direction have any effect on the manufacturing process?
My understanding is the further from 0* the more torque you lose, but you gain speed and there is an efficiency gain, but it's only at a varying rpm range based off the amount of advance rpm. Since you can reduce reverse speed on the tx or esc I run mine at zero.
In classes where you can say only race a 35t motor and you want it faster, advancing the timing makes sense. But i don't see the benefit in my crawling,. I only noticed increasing the advance increased the minimum rpm, so I got rid of it right away. So I may be missing something.
