H8z2luze's EEM SNG bully...
h8z2luze
Oroville, CA
Well this is a new trek for me. First MOA dont make to much fun haha.
The East End Machining SNG chassis came today! Man its awesome! Been working on it for 7 hours. It is driveable but not setup how I want it yet. Anyway. Had to stretch the bottom links out some to get 12 1/4" wheelbase and cut down the uppers. The links were set up for a beetlejuice chassis. It came out pretty good. I will do some testing in the morning before the comp and try to do a couple changes if I can.
Thanks Joe!!!! This package is awesome! Everything you need including a lexan mounting tray!
Built a lexan battery tray on the back axle.
Bottom links worked out great. Not to happy how the shocks mount though. Stupid losi stock mounts...
Need to figure out a better body mounting system lol i have a zip tie holding on the back half.
looking good bud!
are those RC4WD plastic beadlocks?? looks like they are...let us know how they hold up I have been thinking about trying a set to kill some weight.
how much does your rig weight with those wheels..rtr?
thanks
looking good bud!
thanks
im not sure I dont have a scale. They are the plastic rc4wd rims. The holes are actually metal tapped in the beadlock. I think they will hold up great. id guess it weighs like 7 pounds or so but I could be wrong.
Thanks lloyd! Also thanks for all the help.
That would be nice if you were around 7 lbs. And no problem bro.
I think its heavier than that. I have bad stall and need new links. Other than that I think it did pretty well but I do want to get 45T motors.
I ordered new integy 45T motors for it and just got done doing a bunch of stuff.
First off this chassis is amazing.
I took a fellow crawlers advice and mounted my shocks with fuel tubing and it works well. Thanks! Put new revo rod ends on all the links. The uppers had some other type I think they were jato or something but they were what was causing the rig to be loose. Its tight now and flexes well. I took it out today and it did twice as well as yesterday. Still has stall but I think my suspension is pretty dialed how i want it. I put stiffer springs on the back and it made a ton of difference. i love how when I dig it sucks the rig down. It helps so much on vert climbs.
Some pics of the stuff I did today..
My creative body mouts lol
Cut and sanded them down...
Decided to put the panthers back on.
COG seems ok.
Couple with the body. It sits pretty low.
