I came up with a lightweight crossmember for the rear of the H10 Optic that replaces the radiator. I've always thought the radiator VP uses is way too heavy, its a solid chunk of plastic.
The stock radiator is 35g and my crossmember is 3g, shedding 32 grams.
Reuse the stock screws to mount it.
I used Matter hackers build silver PETG which matches the gray cage pretty well.
Printed with increased perimeters so its solid, infill not recommended (threads strip much easier). Print horizontally for the best strength.
You can download the STL for free here: https://www.thingiverse.com/thing:6880362
