H10 Optic LCG electronics tray (3D print)
HumboldtEF
Tiny truck hoarder
Lifetime Gold Baby!
Humboldt county
I came up with a LCG electronics tray for the H10 Optic. It replaces the stock tray and lowers it by about 23mm. This will not work as a servo mount as its too low. Reuse the stock screws to mount it. The extra holes on the corners are just in case you need to zip tie wiring.
Originally I tried to squeeze a Mamba X into the stock tray but its just a bit too tight, now there's tons of room for activities.
I used Matter Hackers build silver PETG which is a pretty good match for the gray cage. I increased perimeters to the point it printed solid, having some infill is fine though.
You can download the STL for free here: https://www.thingiverse.com/thing:6880328
For those who dont have a 3D printer you can also flip the stock tray over after you remove the front portion thats screwed on. There are 4 bosses that are supposed to slot into the tray when mounting it right side up so after flipping it these will be visible between the parts.
