I have considered building another SCX10 for a little while now, but I wanted to focus on a build that would a bit lighter in weight, and be eligible for both Class 1 & 2. I have noticed that the nearly box stock Deadbolt my son has a much easier time with climbs then my decked out, scaled out SCX10 Bronco does. My Bronco weighs about 10lbs with Vanquish Rock Jocks, lights, heavy bumpers, scale interior, roof rack with stuff on it etc. The Bronco looks great and is fun to drive, but it cannot perform anywhere near as well as my sons 5lbs 8oz near stock Deadbolt!
So as I was considering what SCX to start with I looked over at my Bomber and realized that if I bought another cage then I could just about build another stock Bomber with all of the parts that I have replaced... :|
Sooo.... Rather than buy a box SCX and throw away just about everything, I might as well just order parts and build one. I would be ordering all of the same stuff anyway. And this is a good thing because the only "stock" Axial parts that I would have on it are.
1. Rear axles
2. Two of the frame cross braces (and I might change one of those)
3. Body posts
4. Honcho body
I would literally have the whole kit sitting in the parts bin.
So the parts that I am using other than mentioned.
Frame
1. The Scale Shop SCXHR v3 aluminum frame rails (3.8oz)
2. The Scale Shop Smooth Skid
3. Hot Racing locked up transmission
4. Robinson Racing 80t 48p slipper
5. SSD CMS kit
6. RC4WD Tough Armor Side Bars
7. RC Rock Armor Shield front bumper
8. American Machine Works aluminum links
9. Traxxas Slash receiver box
Front Axle
1. SSD D60 axle case
2. Fast Eddie bearings
3. Axial 43/13 U/D gearset
4. GripFab SS Spool
5. Vanquish Stage 1 Chubs and Knuckles
6. Vanquish bushings
7 SSD CVD's (which RPP just got in yesterday so should be here Monday)
8. Vanquish Tie Rod
9. MIP 13360 shafts (set so same for rear)
10. Yeah Racing clamping hex
Rear Axle
4. GripFab SS Spool
5. Vanquish Stage 1 Lockouts
6. Yeah Racing clamping hex
Wheels/Tires/Foams for class 2, have not decided for class 1
1. Boom Racing "Aegis" 1.9 beadlocks (I actually like these things and very heavy for weight down low, whole setup is 2lbs 6oz!)
2. Pitbull Growlers
3. Crawler Innovations Duece's Wild F&R
Electronics
1. Futaba R603FS receiver
2. Hitec 7955TG servo
3. Castle 10 amp BEC
4. Tekin Pro4 3300kv waterproofed
5. Holmes BLS ESC waterproof
6. HeyOk servo winch
Body
1. Dinky Honcho interior to go with body
2. Bunch of little Yeah Racing scaler accessories
So far I have both axles built save for the front CVD's which I am waiting for. I also just realized that I ordered a Wraith/Bomber tie rod, so I need to get the correct stuff now..
The build has gone eerily smooth up to this point save for one item, getting the Chubs onto the SSD housing was nearly impossible. With the bearing out they will go on, but tight. Bearing out and put chubs on it was impossible to get bearing in! So I ended up using a dremel at very low speed (500rpm) to open up the bearing pockets some, but bearings in, and used about 180 of my 230lbs weight to push the axle housing down onto the chubs while the chubs were on a carpet mat. I will probably have to destroy the axle housing to get the chubs off, and that is no joke. I do like the SSD D60 housing, but they need to work on their tolerances. The rear lockouts were just about as hard and I am not the only person to have run into this issue.
So now I need to get the correct tie rod and I am writing on the links to come in. I still need to figure out the best way to mount the winch as well, and I am sure that I am forgetting a few things, but for now a few pictures..
Photobucket is not playing nice today..
Few more
1. Rear axles
3. Body posts
4. Honcho body
Frame
5. SSD CMS kit
Front Axle
4. GripFab SS Spool
8. Vanquish Tie Rod
Rear Axle
4. GripFab SS Spool
2. Pitbull Growlers
Electronics
Body
Few more
