re: "Dutch" Griz's Scale Adventure Trail Rig/G6 Ride 10 Years of RCC Tribute Build
While the Jeep was looking good, between the slight wb stretch up front and the tire size there was going to be interference with the grill at full lock turn and articulation.
My original plan was to do a narrow XR10 mod to the front axle but when I put the wide AXR10 axle under the Wraith I thought it looked good so I decided to go full width.
I decided to try out the RC Bros Burly Tubes for this install. I really liked the idea of having splines on the tubes so I thought I give these a shot.
Install was super easy. Not that the mods for Beef Tubes are hard; but the Burly Tubes were plug and play.
I like to sand down the sharp edges on the housing. I feel it gives a bit more realism.
The other nice feature from RC Bros are these super sano spacers that look nice and clean. After taking all the pics I realized that the spacers were installed backwards but I didn't want to redo all the pics. They are installed correctly now.
I used a drill bit to make sure all the holes were lined up.
Then a quick tap.
The plastic Axial Chubs are a really tight fit, you can see how the tubes shaved off some material. After I cleaned out the shavings the Chubs were able to fully seat.
The Vanquish Chubs go on smooth as buttah and have no slop.
As with either tube option, drilling the holes for the knuckle screws is the worst part. I never can seem to get them in exactly the right spot, but then again I never change the clocking once I get them installed so it's not that big of a deal if they are off a bit.
As you can see, my holes are a bit off but a bit of clearancing took care of that.
I stuffed a piece of paper towel in the tube so chips wouldn't get on the ring gear and I wouldn't have to remove the tubes to clean the chips out.
I couldn't be happier with the RC Bros Burly tubes. I love how you leave the plastic in the housing so that the tubes are held in firmly and the screws only keep the tube from rotating.
I love the splined ends and they are very well machined. I also like how the Chub screw only has to hold the Chub in place on the tube and not stop rotation.
The axle and Chub screws on Guido's Beef Tubes are always coming loose. I have high hopes that the Burly Tubes will not have that problem. I will let you all know soon enough. I plan to spend the money on Burly Tubes again for sure. "thumbsup" Great product guys.
Before the Burly Tubes with Vanquish .350 hubs and OMF beadlocks:
The width with Vanquish .350 hubs and OMF wheels turned out to be a bit too much. I ordered some .225 hubs to see if that fixes it:
The width in the rear with the Vanquish .725 hubs and OMF beadlocks was perfect.
