Great in theory. From what I can tell they did not make any adjustments to keep the drag link and panhard the same length so you will end up with a stock (shorter) drag link resulting in less than ideal steering geometry.
Only solutions would be to move the servo, difficult because the required length would probably put it outside the frame rail. Or knuckles with the mounting location further out which kills ackerman and tire/wheel clearance. So you are stuck trying to mount the servo on the axle or just living with poor geometry.
I cant justify spending the money to make the suspension geometry worse...
Did you notice the drag link is mounted in the new outer hole that was added to the steering mounting points on the axles. This corrects Ackerman angles when turning and requires the drag link to be longer which decreases the drag link angle. This change allows for a slightly longer track bar which in turn helps reduce the side to side movement of the axle during suspension travel and while flexing. Even if the track bar is slightly longer and if adds a tiny amount of bump steer it's not an issue since this is only a low speed vehicle. The trackbar mounting height might be slightly changed also which could easily correct the steering geometry some thus eliminating any added bump steer. I actually find this to be a non-issue for crawling, bump steer is only a real concern at speed anyways.
Correcting the Ackerman angle will improve crawling performance and the relocated shock mounts also increase side hilling stability.
They made many nice improvements beyond stock with their updates they did to the axle housing and knuckle design. If I hadn't bought their high clearance knuckle kit for my stock axles I would have bought these. I still might for my other TRX-4 however.
Thank you very much..Did you notice the drag link is mounted in the new outer hole that was added to the steering mounting points on the axles. This corrects Ackerman angles when turning and requires the drag link to be longer which decreases the drag link angle. This change allows for a slightly longer track bar which in turn helps reduce the side to side movement of the axle during suspension travel and while flexing. Even if the track bar is slightly longer and if adds a tiny amount of bump steer it's not an issue since this is only a low speed vehicle. The trackbar mounting height might be slightly changed also which could easily correct the steering geometry some thus eliminating any added bump steer. I actually find this to be a non-issue for crawling, bump steer is only a real concern at speed anyways.
Now I'm even more confused, but this seems like a good turnout after all then..
Man I'm not getting any sleep tonight..
Just buy a set, you'll sleep fine tonight then. "thumbsup"
Pretty sure the guy who designs scale trucks for a living gets how steering geometry works.
Unpossible. The shill that posts nothing but parts for the company knows more. :lol:
Shills definitely know best, that's how all my servo and tire purchases are determined.
I didn't get this message before I fell asleep, and I for sure didn't sleep any good..![]()
But I guess I'll sleep like an infant tonight, the order for a black set is effected and I'm allready waiting for it to arrive..![]()
Brandon designs scale trucks for a living????
