i ordered 2 elite 4800 25c packs and the elite 5i bc. i read the instructiopns a couple of times but iam confused about what to set the charger at for charging the packs.
i was told that you charge at 1 amp for ever 1000 mah of the pack by a friend. so for a 4800 i would charge at 4.8 amps ? but if i understood the instructions to the charger correctly i should charge at half of the packs capacity ? which would be 2.4 amps ??
also i never read anything about if it was ok to hook the charger up to a power supply, i have a 14amp power supply,would that be ok to charge with.
also should i buy a lipo sack...sorry for all the questions, i just want to be safe.
thanks for the help.
**EDIT**
this is the part from the instructions that isnt to clear to me...
Lithium polymer battery program
These programs are only suitable for charging and discharging Lithium-polymer batteries with a
nominal voltage of 3.7V/cell.These batteries need to adopt different charge techniques and are
termed a constant voltage (CV) and constant current (CC) method. The charge current varies
according to the battery capacity, and is usually C/2 rate (half capacity as a charge current). The
final voltage of the charge process is also very important. It should be 4.2V/cell for the nominal
voltage of 3.7V/cell. If the final voltage exceeds 4.2V you may be risking the chance of fire or
explosion of the battery. This is why it is important to set the correct Lipo program before you
begin charging. If you want to alter the parameter value in the program, press “Start Enter “key to
make it blink then change the value with “DEC” or “INC” key. The value can be stored by pressing
“Start Enter” key once more.
**EDIT**
