Good shock postions.
cain
melbourne
Hello,
does anyone have any good shock mods and new postitons to mount there shocks if so plz leave a photo or message.:mrgreen:
I guess the first question would be what chassis are you running? I run a mostly stock chassis and can show you what I have.
i run teh stock chassie with 4" losi shocks. i have them mounted 5mm off the chassie on the back and 12mm of the chassie in the front. on the rear axle they are mounted on the outside of lowerlink mounts. on the front they are 8mm in on the inside of the lowerlink mounts.
This is what I run if you have a stock chassis. I'm getting 60 degrees sprung and 62 degrees running droop.
front susp
rear set up
Hope this helps!
