I did the portal upgrade on my gen 7 pro. It seemed the high steer wasn’t a real solution as every review had problems.
Plus the portals have extra clearance... which has transformed the truck immensely.
But i have a problem with the steering. Turning left is fine, but turning right, the servo seems to be at equal distance but it’s a lack luster angle. I have the oem controller switch up to 100%. If I kept it at 50-70% or what ever the oem instructions say, the steering is pathetic left and right.
It almost looks like a longer steering horn might solve this problem.
I will happily put a new servo in if it’s a direct plug and play (I really don’t want to get into new esc and other electronic bits, just a plug in servo for now)
I have quadruple checked to make sure the servo is in the middle of its stroke when zero’d.
So it’s not a “horn is off the splines”.... but to be honest, I can’t remember if I tried to install the horn clocked to the rights advantage or not. I want to say I did and couldn’t get enough trim correction on the controller. It’s been a bit and I’ve had too many concussions and have a terrible memory.
Can anyone help with a solution?
