Gearing question YETI X
Thickone
Kahnawake
Yeti x conversion done. I got under drive in the rear, stock slash platinum gears on the front. Should I leave the gears alone or should I switch one of them out? And to what gear?
slash is 13/37 = 2.84
underdrive is 13/43 = 3.3
I'd step to the standard hd gears, 13/38 =2.92
Good luck "thumbsup"
if you. plan to go fast, you don't want have differenz between front /rear because too much steess on the drive train..
Gesendet von meinem T1-A21L mit Tapatalk
