Great looking Lux!
Great looking Lux!
Thanks man, the cab mount had to be strong for my driving:mrgreen:. Have you broken any AR44 ring gear/locker bolts?
such a beautiful build.
I have yet to shear one or have one back out... I use 12.9 hardware and I clean the spool threads, wipe off the ring gear, and hardware with rubbing alcohol prior to assembly. I then give the blue permatex time to set up before the green sticky grease is applied. I can only guess folks are having issues with spool hardware due to improper assembly... I just like the idea of your solution. The spools for the 10.2 are cheap enough to toss when the ring gear has served its life sentence... :mrgreen:
Thank You
Nice, I have broken 5 AR44 Locker/ring gear bolts and can say improper assembly was not the fault for the bolts breaking but rather good traction, torque, weight, and drive time destroys these three bolt lockers.
Well Gavin, if you beat on anything long enough you will have failure.. I have seen many complain of premature hardware breakage and this is why I use 12.9 for the super tiny hardware... I use your pops foams in every tire I run and only run sticky rubber.... I gear down so I am certain I know of this traction thing your talking about...:shock:
