Ftx 1/24 outback mini scale crawler
MattTheGenus
Las Vegas
New micro crawler headed our way, it actually looks pretty good. I'm mostly excited to have some nice soft micro super swampers (finally)
* Solid axles, full time 4wd
* Four gear transmission
* Multi-link, coil spring suspension
* Fully proportional throttle and steering
* 4 cell NiMH 220mAh battery with USB charger
* Classic ‘80’s style body
* Roll bar
* LED lighting
* 2.4GHz radio, 2-n-1 ESC/receiver
* Super soft tires
* Ground clearance- 25mm
* Width- 105mm
* Length- 210mm
FTX 1/24 Outback Mini Scale Crawler « Big Squid RC – News, Reviews, Videos, and More!
I wonder how the dimensions will work with the plastic 1/24 scale bodies. Did a quick look and width wise seems to be pretty good for many of the revell model trucks
The sumo crawler is also listed as 105mm wide, really too wide for 1/24 stuff. Will work for 1/20 though.
See also the ECX Barrage: Barrage, Blue: 1/24 4WD RTR (ECX00017T2): ECX RC
Same chassis, but much better body IMHO. Tires are different as well. The FTX tires look better to me.
They look pretty good. I do like the Exc body but I didn’t really it the video. Looks like a great scale base to start from.
Copied my post from the FB group.
"Saw this the other day. Looks like it will be the same wheelbase as a Losi Trail Trekker and the same width as a sumo crawler, but the 310mm length (over 12 inches) seems like a typo.
Those diff pumpkins look large so hopefully it has lower axle gearing via larger gears than the Sumo and Mini Gelande.
The tires will be 1 or 2 mm shorter than the losi Micro Crawler which would make them the shortest micro crawler tire available, where most are about the height of the Trail trekker.
Mini FTX dimensions
Length: 310mm
Width: 105mm
Wheelbase: 122mm
Height: 100mm
Ground Clearance: 25mm
Tyre: ø 46mm x 19mm
RC4WD Mini Gelande 2 dimensions
Wheelbase: 130.75mm (5.115")
Width: 108.08mm (4.3")
Height: 120.53mm (4.7")
Ground clearance: 30.74mm (1.21")
Losi Trail Trekker dimensions.
Length:6.89 in (175mm)
Width:3.7 in (94mm)
Height:4.9 in (124.5mm)
Wheelbase:4.8 in (122mm)
Sumo crawler dimensions
Length 170mm
Width 105mm
Height 70mm (Without Body)
Wheelbase 120mm
Ground Clearance 70mm
Proline Ambush
Length: 7.80" [198mm]
Width: 3.75" [95mm]
Wheelbase: 4.52" [115mm]"
Sent from my SM-N900T using Tapatalk
It says "80s style body" but the body definitely looks closer to a 90s Toyota with at most 80s Toyota fender flares.
Can't help but suggest an alternative: Get a Proline Ambush body and retrofit it either on this truck or on any 1/24 truck/crawler you might already have.
Looks pretty good and has standard ring and pinion axles like Proline should have done wtih the Ambush! I might buy one. :)
Or... any 1/24 scale model kit?
Just watched the vid and yes, needs gear down.
And all i could think was
"Hey babe, dinner is ready for AW DAMMIT CHRIS! REALLY?!!?"
The reason companies like Proline, Losi, and ECX use worm gears at this scale is to make them slow enough to crawl. Otherwise with ring and pinion geared axles your left with a vehicle with too much speed to have enough control to crawl. Then, like stated above, your left looking for ways of gearing down. Which options are very limited at this scale.
Exactly what I always say. Worm gears may not be scale looking, but at this size especially with micros you get much lower gearing in the axle and it's much smoother. To get that much reduction in a micro ring and pinion you'd need a huge pumpkin. This is why all the ring and pinion micro axles are comparatively higher geared.
A geared motor like in the Orlandoo would work if it was attached to a transfer case. Forward mount the motor while you're at it.
X2 and the tires are smaller diameter so should be ok with proper setup? Might need larger spur gear?
Did I miss something? The Sumo uses ring & pinion axles and is comparable in speed and power to worm gear axles, remember, there is reduction at the transmission too... the benefit I see to worm geared axles is that you can get by with a cheap ESC that doesn't have a drag brake.
Axle reduction isn't always the same as as reduction at the transmission. That's why people swap axle gears in 1/1 and larger RC like 1/10
IMO while I like both the Sumo and losi, I don't find them to be similar as far as crawling.
