I've got a Baja Rey with SSD front bulkhead, Hot Racing steering setup, and RPM front arms. I understand that I added a bit of weight to the front end, but the shocks simply won't properly support the front end. After setting the truck down, there is very little sag. When I press down on the front, it bottoms out and barely springs back up, almost zero rebound.
I've got my stiffest springs (Gmade XD "HARD") of nearly identical length to the stock springs on them. I've taken emery cloth to all of the hinge pins, scrubbed the contacting surfaces on the arms, put the anti-roll bar back in, and wound the preload all the way down. There doesn't seem to be any binding in the suspension with the shocks removed and I'm fairly certain that I have enough spring to support the front end. I'm left looking for any other possibilities. Anyone have any ideas?
