My son was just running his Poison Spyder and may have fried his first motor. It is basically stock with the exception of metal transmission gears, front universals, vanquish hubs, and an upgraded deans battery connector. Battery is a Venom 25C 5000mah. He was climbing through a small ravine and having trouble with a rock when one of the wheels locked up and next thing you know a big puff of smoke- see attached pic. I am assuming he fried the motor? The sheathing on the motor leads appear melted and things were quite hot. The truck had been running for about 20 minutes on mixed terrain and speeds. Gear ratio is stock.
My understanding of electric motors is basic at best... any advice on a replacement? he enjoys tearing around the back yard, building small jumps, etc, but also enjoys when we go to the park or places where he can attempt some crawling. Is there a good one size fits all replacement? should we stick with stock since that help up ok and seems to be reasonably priced? And/ or should I consider getting him a lower ratio set of spur and pinion gears to swap out when we are going crawling- which is once in a while and then he could run the faster gear setup when running at higher speeds in the back yard? As always, appreciate your help.
Josh
Josh
