Did some more research and will answer my own question in case someone else stumbles across this.
Standard Motor Rotation = CCW when looking at pinion
Reverse Motor Rotation = CW when looking at pinion
So, in my particular truck (which I got used) if I roll the truck forward and look at the fan in the motor turning I can see it's turning from driver side towards passenger side, or CCW when looking at pinion. So, my suspicion is that the prior owner flipped the diffs to run it with standard motors.
My wraith is still setup in stock configuration and when I roll mines forward, the rear of my motor spins CW (i.e. the pinion will be spinning CCW). Apparently some Wraiths come setup for Standard Rotation motors from factory..
