excellent!
Agreed and thank you"thumbsup"
Your son is very talented. He's the future, God bless
I appreciate the kind words, thank you.
excellent!
excellent!
Regarding welding the spools to the ring gear; are there any issues with the hardness of the gears?
The only reason I decided not to try it was because I didnt want to ruin the heat treat. I figured it would make the ring gear too soft.
Any insight?
Thanks!
I don't know if the heat treat is affected. What I know Clean spool and ring gear clean of grease! I soak with gas and clean with simple green. I then use acetone to clean further. I attach the ring gear to the spool with the bolt holes not lining up so I can get the best weld Penetration. I heat up the spool for 30 secs with a torch let cool repeat. I then heat up the spool and Tig Weld all three holes. I let the spool cool. I file any excess weld above the ring gear to allow the bearing to fit. I don't think the gear heat treat is affected because I have broken many locker bolts but never broken one of my welded lockers or stripped a ring gear! I have 8 lockers welded and in RC'S still running today! I have Tig welded Axial gear to VP spool, VP gear To VP spool along with HR gear to HR spool and mixing them VP gear to HR spool. I prefer to use VP spools with vp low ratio gear and HR High ratio gear. That is my insight. If you have a 6lb rig that you drive hard I would definitely recommend welding the gears or if you want to never have to fix a broken locker bolt out on the trail weld it "thumbsup".
