Fms smasher
chevy4life
CALDWELL
Hello all, Looking for some opinions. I currently have an axial deadbolt 24 and am looking for something similar in size but not a crawler. Something with maybe a little more speed. I'm thinking of the FMS smasher. Anyone got one and have opinions on it? Is it worth the money? Does it perform well? Etc.
The FMS FCX24 trucks are awesome. Any of them should suit your needs with the 2speed transmission, however the smasher has an open differential instead of a locked spool gear which is better for turns. You can easily swap any of the FCX24 axle gears back and forth if you'd like as well. if you're going for speed you'll probably want to upgrade the stock battery to something with a higher "burst" c rating however.
Sent from my Pixel 6a using Tapatalk
NWCT24CRAWL. Thanks. I have read your post and going to pull the plug on it. Looks like I'm going to be placing an order for some hope up's as well. Good looking rig by the way.
