kaneohecrawler
So a while back I had made a bikine soft top for my custom caged tj. After a while it was to worn out. So I removed it and left just the bare cage. Don't get me wrong I'm very proud of the cage I made and don't wanna hide it under a top, but I'm pretty good with fiber glass so I got an idea. Took a piece of thick glass pre impreganted it and laid it over the top of the cage and let it conform to all the curves this beauty has.. after it dried I peeled it off and trimed around all the edges. It was a little contorted being it was so thin so I put a dab of CA on all 4 corners to make sure it laid flat to the cage. Once it was ready I proceded to lay 10 layers of thin/fine fiberglass impregnating as each layer was applied. Once all that was dry it still had a "cloth" look to it. So gave it a quick sand and painted it with resin to give it a nice smooth finish. As soon as all was fully cured I trimmed all the edges. The top was then removed since I had it glued down. It still had "slight twist in it so I removed the cage wrapped tape around the bars in all 4 corners, and and where the tape was I formed some "hooks" out of chopped fiberglass mixed with resin so that the top would clip into the cage and not have to have any zip ties or anything to hold it on so it has a nice and clean look to it. After all was said and done I wet sanded and gave a simple flat black paint and man does it look nice.
Let me know your thoughts. On to the pics. Thx for looking.
