I built the TRX-4 chassis kit, and am now building the Sport kit as well, and am curious what purpose the extended stub axles (TRA8255A) serve? I've got the 72 Blazer body on the way, and noticed the wheels that "go with" that body require these extended axles. Is it the wheel/rim itself that's wider than what comes with the kits? I have some Injora bead locks with the stock tires and they fit just fine with my current Bronco body... Do they widen the stance/track or something? Perhaps they're longer to give the screw on center hubs a bit of thread to bite into?
Also, anyone running the MIP 4mm (per side) wide track offsets? Considering grabbing those to widen things up a tad.
Thanks!
Thanks!
