Ok i bought a spektrum DX5e today knowing it only had a 2 position switch with little money. I also noticed that just by looking at the thing you could totally tell the trainers switch could be modified to be the 3rd position switch. im just in need of some assistance like were to cut into the 5th channel switch's line to tie the adjuster pot for the 3rd position and so on.. here are some inside pics below.
(thougth just in) could i cut the trainers switch lines, strip the 5th channel's switch's lines solder negative to positive but with a pot adjuster in between the line? and would i need a diode before it??
